For loop doesn't loop when Runstate.LoopIndex is used.
How does RunState.LoopIndex works? I have the following setup but Runstate.LoopIndex keeps initializing to 0 after first run.
If I use Locals.Index then for loop runs as expected.
Thanks!!
CLD
(1,518 Views)
Accepted by lvrat
RunState.LoopIndex is only valid for the life of a step and then each step resets it back to 0.... at least that's how I understand it.
LoopIndex should only be used for looping within a single step and not for the flow control steps.  You correct in using Locals for that.
From the Help:
LoopIndex Property
Syntax
SequenceContext.LoopIndex
Data Type
Long
Purpose
Specifies the value of the loop index at a given point as a step loops. The value of the loop index depends on the looping construct you select for the step.
Remarks
Note  This property returns the value of the loop index truncated to a 32-bit integer. To retrieve the underlying 64-bit floating point loop index, call SequenceContext.AsPropertyObject().GetValNumber("RunState.LoopIndex", 0).
jigg
CTA, CLA
testeract.com
(1,484 Views)
