NI TestStand
FrontEndCallback SequenceFileLoad Callback Problems
As our TS System is initialised I am seeing functionality in the SequenceFileLoad Callback of our Test System Process Model being called before functionality in the FrontEndCallback, is this right?
Confused (even more then usual)
Steve
There are 10 types of people in the world that understand binary, those that do and those that don't.
(3,346 Views)
Hi Steve,
Are you loading this sequence from the sequence editor or an operator interface? Do you mean that you don't get the Login dialog box until a sequence file is loaded?
Regards
Jon B
NIUK
(3,337 Views)
Hi Jon
I am running with the Sequence Edior at the moment but ultimately I will be running using a UI.  We see the FrontEndCallback Login happen and then stuff inside the SequenceFileLoad starts to run and then stuff after the login inside the FrontEndCallback starts to run, everything gets confused (includng me) and the system falls over.
I thought the FrontEndCallback would complete before anything else runs, but it looks like after completing Login everything else is allowed to run.
Steve
(3,336 Views)
Hi Steve,
Can you post your FrontEndCallbacks Sequence file?
Cheers
Jon
(3,332 Views)
