NI TestStand
teststand: alphabetically order sequences
When selecting sequences from the sequences available (for sequence calls or when listing All Sequences) they are not in alphabetical order, is there a way of changing this?
thanks
(3,093 Views)
You will find there are in the order, as seen in the All Sequence View.
There is no tool that will put these in alphabetical order. if there are not many sequences within your sequencefile then you would have to manually sort the sequences in the All Sequence View. Otherwise you would have to generate a Sequence File that would use the TS API methods to sort a given sequence file.
Regards
Ray Farmer
Regards
Ray Farmer
(3,092 Views)
ok, thanks Ray
Nigel
(3,089 Views)
