NI TestStand
Full OI execution window -does not show running sequence steps
Hi Everyone,
We have been using a deployed TestStand application (with full OI) that was working fine for a couple of years and suddenly the execution window does not show any of the running sequence steps. TestStand 2010 and Labview 2011.
We know the test application is running fine because we have a full test report at the end of the test.  However, not sure what has changed, as we don’t see any sequence steps running.
Any suggestions?
(5,597 Views)
Accepted by tstand
Is tracing disabled.  You can check by going to Configure>>Station Options... and look at the Execution tab.  Enable Tracing should be checked.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(5,594 Views)
Thanks ~jiggawax~!!!
(5,578 Views)
I have the same problem with trace steps not visible. But "Enable Tracing" under "Configure>>Station Options.." is enabled (and "Allow Tracing into Setup/Cleanup" is also checked).
(2,722 Views)
Using View -> Reset UI Configuration cleared the problem. The display of the progression of the program steps are visible again.
(2,710 Views)
