NI TestStand
Full recording or failures alone to report
I want to have the report such a way that, if a particular flag is set report should contain both pass and failure step statuses. Where as if the falg is not set then only the status of failure steps to be logged to test report.
Pl help me in solving the above issue.
regards,
Ramjee V
(3,644 Views)
you could use the filter option, checkout the following:
http://zone.ni.com/devzone/cda/tut/p/id/8289
In figure 1 there is a control called Result Filtering Expression, you can set this for failed results (providing your are not using XML)
or else you can try the Result Expression for modify the report path and send the Failed result to a separate failed
see
http://forums.ni.com/ni/board/message?board.id=330&thread.id=29160
Regards
Ray Farmer
Regards
Ray Farmer
(3,640 Views)
Hi Ray Farmer,
I tried setting the ResultFilterExpression as follows:
Parameters.ReportOptions.ResultFilterExpression = "Result.Status != Passed && Result.Status != Done && Result.Status != Skipped". I was getting error.
Pl correct me.
regards,
Ramjee V
(3,637 Views)
Accepted by ramjeev
try
Parameters.ReportOptions.ResultFilterExpression = "Result.Status != \"Passed\" && Result.Status != \"Done\" && Result.Status != \"Skipped\""
check out
http://forums.ni.com/ni/board/message?board.id=330&message.id=12930&query.id=4179360#M12930
regards
ray farmer
Regards
Ray Farmer
(3,633 Views)
Thanks Ray Farmer.
Ramjee
(3,615 Views)
