NI TestStand
Generate TestStand Sequence according to TestStand Environment settings
I want to generate a TS sequence file (TS2017) in Labview 2015, and I have a TS environment, where all the custom steptypes are stored which will be needed.
After opening the IEngine I cannot find the method which could specify the right path to the TS environment file.
Did someone have some experience with this?
CsBihacker
(2,548 Views)
Accepted by topic author CsBihacker
Found the solution, it was the method EngineInitializer.SetEnvironmentPath, which needs to be called before the Engine is initiated.
CsBihacker
(2,493 Views)
