NI TestStand
TestStand 3.1 Error
Hi all,
I exprencing the following error when I try to start any  test stand (3.1) sequence.
then when I continue I get the following error.
I believe these  two issues are related to together but I'm unable to find any clue where might be the error or the root cause of the fail.
These steps are using custom step type and custom DLLs.
Has any one got any similar experience ?
or any advice is highly appreciated.
(2,585 Views)
Hey! This seems that you don't have Traditional NI-DAQ installed on your computer.
Try to download it, install it and then see if it works!
(2,541 Views)
