NI TestStand
Generate sequence file from ATML 1671.1 file
I'd like to programmatically generate a sequence file from an ATML Test Description file. I've looked at the SequenceFileXML Parser example, and that does a lot of what I need, but it's reading from a different XML format. Can anyone here point me in the right direction?
Thank you!
(2,780 Views)
Accepted by Zzyzx_Zybisco
Hey,
NI makes a toolkit that has this functionality. Check out the TestStand ATML Toolkit and download an evaluation version of the product. If you have any problems, let us know!
(2,763 Views)
Excellent. Thanks!
(2,732 Views)
