NI TestStand
Get LoopNumIterations from different SequenceContext
Hi there,
my problem is that I need to know the LoopNumIterations and LoopIndex from a different SequenceContext. The question is how to get a SequenceContext from a different Sequence or is there a better method to do this?
My Operator Interface is written in C# and the ProcessModelPostStep Sequence is sending PostUIMessage(10001,0,"",RunState.CallingStep,True). The Eventhandler of this PostUIMessage in my Operator Interface needs to know if the CallingStep is looping or not and if looping I need to know the loopnumiterations and the loopindex
(3,368 Views)
Within the ProcessModelPostStep, 'RunState.Caller.RunState.Caller.Step.TS.LoopType' will tell you whether the caller step is looping.
If its the Step that is looping then RunState.Caller.Step.TS.LoopType will indicating its loop type.
This is a string property and will contain "NoLooping" as the default.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,361 Views)
No unfortunately not. I mean the looping witch is set in the step property not the from the context menü (TestStand 4.0)
The Information I need is in SequenceContext (RunState).LoopIndex and SequenceContext.LoopNumIterations. The problem is that my evant handler has an other SequenceContext because it is in an other Sequence "ProcessModelPostStep" and not "MainSequence" or somthing like that. I can't use the following pseudocode because the variables loopidx and loopnumit are always 0
int
frameID = 0,loopidx=0,loopnumit=0;
NationalInstruments.TestStand.Interop.API.SequenceContext ctx = niExcecution.ForegroundThread.GetSequenceContext(0, out frameID);
loopidx=ctx.LoopIndex;
loopnumit=ctx.LoopNumIterations;
(3,359 Views)
You dont what to be using the Foreground Thread because thats the thread your OI is running in, You need the back ground thread pointed too by an index value.
The obtaining the SequenceContext of that thread you need to get down to the Step reference to identify whether its looping before obtain the loopindex etc.
Regards
Ray Farmer
Regards
Ray Farmer
(3,353 Views)
