NI TestStand
Get Step Name
I'm using TS 2014 and custom  OI GUI on C#.
I've implemented  UIMsg_ModelState_TestingComplete  and successfully get status of my  <Stop On Fail>  test sequence by calling uiMsg.StringData.
In case the sequence is failed I'd like to display the name of the failed step. How can I do this?
Message 1 of 11
(5,063 Views)
Where do you want to display it at?  In a popup?  Or just on a form control?  Or in the Status Bar?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 2 of 11
(5,013 Views)
You should work throught the Black UI example contained here.
Norbert
Expert: Geometry
Message 3 of 11
(5,010 Views)
I'm going to display it on the DataGridView form control
Message 4 of 11
(5,003 Views)
Hi airspan,
Have you had a chance to look through the example Norbert linked to?
Justin
Message 5 of 11
(4,982 Views)
I'm not well versed in C# but have you seen this: https://stackoverflow.com/questions/479329/how-to-bind-a-liststring-to-a-datagridview-control
I think what you need to do is in the UI Message callback set your datagridview to a dataset that contains the name of the failed step.
jigg
CTA, CLA
testeract.com
Message 6 of 11
(4,978 Views)
To be a little more specific:
If you are dead set on using that UI message you referenced then you would get the ActiveXDataParam as the sequence context.  This will then give you access to the MainSequence result list.  You would need to recurse through that and look for the step that caused the failure.  Once you have that step or steps then you would create a List that can become the dataset for your DataViewGrid.
jigg
CTA, CLA
testeract.com
Message 7 of 11
(4,977 Views)
To add to jigg's reply with the dead set to this UI Message:
It is not sufficient to identify the first failing step. You have to verify that this step was causing the sequence to fail (step setting: Step Failure Causes Sequence Failure).
Norbert
Expert: Geometry
Message 8 of 11
(4,960 Views)
My problem is getting access to MainSequence result list. I didn't understand what exactly I have to do...
Message 9 of 11
(4,956 Views)
There are 2 ways to get access to the MainSequence result list.
ThisContext.Locals.ResultList[0].TS.SequenceCall.ResultList
OR
RunState.Sequence.Main["MainSequence Callback"].LastStepResult
Hope this helps,
jigg
CTA, CLA
testeract.com
Message 10 of 11
(4,951 Views)
