NI TestStand
Get VI Reference of the VI that is to be run using the action (custom) step
I am currently working on a custom action step. The called VI will self load all the FP values from a configuration file. But I need to be able to pass some values from TestStand using the inputs in the VI Connector Pane. So, if I make the file load happen in the pre-step instead, I will be able to accomplish this.
My issue is that the called VI is of a preallocated clone type. So, I cannot accomplish this with just having the VI path alone as I would be needing the clone instance itself. Is there a way, within the pre-step, I can obtain access to the clone instance that is to be called by the action step?
Arul
(2,629 Views)
It might be noteworthy to state that you can have multiple pre-step substeps for a custom step type.  They run in the order that they show up in the list.  So you could have one pre-step get the reference to the clone and then the other can do the file load.
Just a thought,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,595 Views)
Even if I get a clone reference in a pre-step, that will not be the reference of the actual clone that will be called by the action step itself, right?
(2,575 Views)
