NI TestStand
How can i export/import limits from an external text file?
i have ~1000 teststeps with limits in my testplan.
Now i want to import the limits from a textfile.
What do i have to do?
Create a StationGlobal for each limit and create a new teststep (which must be called 1000x) which reads an inifile and outputs the limit into the StationGlobal at start of testplan?
Something like: GetLimit("c:\limits.ini","teststep230_low", out value)
OR
Is there a builtin method to export all limits into a file and re-import this file automatically at teststart?
Thanks for help
(2,789 Views)
You can use the Import/Export tool (Tools>>Import/Export Properties...) to export your items and then use the Property Loader step to import them.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,782 Views)
I should have noted that there are shipping examples that show how to do this.
C:\Users\Public\Documents\National Instruments\TestStand 2014 (32-bit)\Examples\Built-In Step Types\Property Loader Step Type
jigg
CTA, CLA
testeract.com
(2,771 Views)
