NI TestStand
Get locals and globals using API
Hi, I am making in LV an editor for TS. User should be able to change the value of file globals and locals variables. Using TS API, is possible to get all the file globals and locals variables without knowing the name that those variable have in TS? I mean, if I knew the name I could use the Get Property Value with the lookup string. But if the I do not know the name of the variable, can I get the list (and their values) of the variable?
Thanks a lot.
(3,711 Views)
Accepted by logatto
Try the following link
http://forums.ni.com/ni/board/message?board.id=330&message.id=3390&query.id=6624776#M3390
In summary:
Use GetNumSubProperties method to get the total number of Locals / FileGlobals.
Use GetNthSubProperty to get the sub properties using the an index starting at 0 to GetNumSubProperties-1
Use the Name property to obtain the Name of the subproperty.
Regards
Ray Farmer
Regards
Ray Farmer
(3,704 Views)
These links maybe more useful
http://digital.ni.com/public.nsf/allkb/5C08014017AA895686256DD6008323FB
the following as examples
http://sine.ni.com/devzone/cda/epd/p/id/3086
regards
Ray Farmer
Regards
Ray Farmer
(3,696 Views)
We have a tool where I work, where we create a MSWord document based on the sequence file.  The tool reads all the locals, parameters, and File Globals names and values and populates the document.   Here is an attached VI to read the names ( comments and variable type ) of the all the locals.  It may be a good starting point...
PH
(3,690 Views)
Thanks all guys.
All very useful.
(3,679 Views)
