NI TestStand
Get property value compatibililty issue
VI:s greated on TestStand 1.0, using "get property value" fuctions does not work with TestStand version 3.5.
How can I use old, well known VI:s, using these problem causing functions?
Can I somehow use 1.0 and 3.5 get property values parallelly?
I have these VI:s something like 50pcs, so I do not want to update all of those manually.
-Teemu
Message Edited by Teemu from Finland on 09-19-2007 03:11 AM
(3,277 Views)
  can you post a simple TS 1.0 sequence we can work against?
Sacha Emery
ATE Systems Engineer
National Instruments UK and Ireland
// it takes almost no time to rate an answer Smiley Wink
(3,182 Views)
As a hint to our support staff, I have a vague and ancient recollection of a LabVIEW issue where you needed to upgrade your VI versions by mass compiling before opening the VIs after you installed an upgrade of TestStand that crossed a certain version boundary.
I think the versions to check the release notes and readme's for clues would be somewhere around the TS 2.0/2.0.1 and the LabVIEW 5.1/5.1f1 timeframe.
The problem was that earlier versions of LabVIEW didn't store ActiveX call information correctly such that certain usually compatible changes to a server (TestStand, in this case) could break a VI with ActiveX nodes, requiring the nodes to be respecified.  However if you upgraded and compiled in the right order, you could avoid the problem.
Unfortunately, that's all I remember. This was many years ago.
(3,177 Views)
I thought you were prompted to mass compile all VI's when installing TestStand.
Regards
Ray
Regards
Ray Farmer
(3,162 Views)
