NI TestStand
SetValStringByOffset
How do I write 2D array of information to the TestStand TemporaryGlobals.  I am able to "set" and "get" a single string but can't figure out how to work with arrays.
(3,400 Views)
  the usual way when working with arays is to do it through a variant instead.
You don't say whether you're using the API in LabVIEW, LabWindows/CVI, c#, vb c++ etc etc or directly in the sequence itself, so the actual calls will depend on the source of the new values and where you're interacting with TestStand from.
Have a look in the examples folder for the passing arrays examples. Hopefully that will give you a good starting point.
Sacha Emery
ATE Systems Engineer
National Instrument UK and Ireland
// it takes almost no time to rate an answer Smiley Wink
(3,380 Views)
Hi Ed,
I don't know if this will help or not but consider the following expression:
RunState.Engine.TemporaryGlobals.NewSubProperty("MyArray", PropValType_NamedType, 0, "Array2DofNum", 0)
This will insert a new sub property into your temp globals.
MyArray is the new name of the new 2D array.
PropValType_NamedType means that I want to use a specified type in my type pallette.
The 3rd parameter = 0 which means I don't want an array of my named type.
Array2DofNum is a data type I created in my type pallette that is a 2D array of numbers.
The last parameter is the default behavior.
You can read about this API call in the help under PropertyObjects.  Because Engine.TemporaryGlobals is simply a Property Object.
Let me know if this helps.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,368 Views)
One more thing,
To set values in this array call this expression:
RunState.Engine.TemporaryGlobals.MyArray[5][1] = 3
This sets the index at row 5 column 1 equal to 3.
It worked for me this way.
jigg
CTA, CLA
testeract.com
(3,359 Views)
