Get result list in TS2013
I want to get the TS2013 result list to custom the report in labview vi, but it error at get the property object of "MainSequenceResult->TS", please help me ,thanks
Message 1 of 9
(5,917 Views)
anybody here??
Message 2 of 9
(5,891 Views)
First off, getting no answer for some hours is no reason to ping.... compared to LV there are less TS users, so answers can/will take more time in average (except, dug is replying 🙂 ).
Looking at your screenshot implies that you worked with a previous version of TS and try to convert some customized components to TS 2013 now. Which version have you used?
 I guess something like 2010 or older....
General feedback:
- You are looking for TestSocket[0] statically. Why?
- Do you use your customized Batch process model? If not, why? BTW: This is most likely the explanation of your issue.
- Try to clean up the wiring a bit. While it is "OK", it could be improved (more space between nodes, no wires behind objects,...)
Norbert
Norbert
Expert: Geometry
Message 3 of 9
(5,882 Views)
HI
Thanks for you answer
Yes,I use my customized Batch process model, and my TS and LV version is 2013
Message 4 of 9
(5,869 Views)
Sadly, you answered only some of the questions:
Your custom Batch model comes from an older version of TS. Is that correct?
Why are you only refering to the size of the ResultList of Socket 0? Doesn't it make more sense to look in each individual socket?
Norbert
Norbert
Expert: Geometry
Message 5 of 9
(5,852 Views)
When you moved your process model to 2013 did you copy all of the files involved (entire directory tree), not just the sequence file? Have you tried looking at the variables in the sequence editor while at a breakpoint to get a better idea of what's going on?
You should be able to use your old process model in 2013 as long as you copied/included all of the files involved in its implementation (even if you didn't modify them). If you aren't sure if you've done that, copy all of the process model files from the teststand version from which your process model is based and then copy your modified files on top of that.
For example, if your process model was based on the one from 2010 and you are on Windows 7 (file locations are different on XP):
1) Copy everything from C:\Program Files (x86)\National Instruments\TestStand 2010\Components\Models\TestStandModels to C:\Users\Public\Documents\National Instruments\TestStand 2013\Components\Models\TestStandModels
2) Copy your modified process model files to C:\Users\Public\Documents\National Instruments\TestStand 2013\Components\Models\TestStandModels overwriting anything that's already there.
Hope this helps,
-Doug
Message 6 of 9
(5,842 Views)
I' m sorry, Because my English is not very good, so it may not very clear presentation
I use windows7 and TS2013, The attachment"get result list size.jpg" is looking at the variables in the sequence editor while at a breakpoint, attachment"Error.jpg" is error information when access variable "TestSocket.MainSequenceResult->TS.SequenceCall.ResultList", Why I want to get the ResultList,because it include all step's result and other information
Now the problem I encountered was I don't know what is the "Referenced Object", When I use the mouse to click on it, it goes blank, I copy the "ResultList" and paste it in a string, it show like this "TestSocket.MainSequenceResult->TS.SequenceCall.ResultList"
Message 7 of 9
(6,454 Views)
Accepted by tonygan
Change the "->" to "."
Lookup strings do not understand "->". That's only allowed in expressions (I agree that it's odd that lookupstrings don't support -> so I'm going to submit a suggestion that they do.
Another way to handle this is:
mainresults = GetValInterface("TestSocket.MainSequenceResult", 0);
then
mainresults.GetPropertyObject("TS.SequenceCall.ResultList", 0);
but using a "." instead of "->" will also work.
-Doug
Message 8 of 9
(5,802 Views)
HI Dug9000
Thank you very much for you help, Smiley Very HappyThe problem has been solved
Message 9 of 9
(5,791 Views)
