NI TestStand
Get the report of only one sequence in TestStand 2012
Greetings...I tell your that I am new to TestStand and I have been doing a test system consisting of 4 sequences. So far I have managed to run the UUTs test and I have obtained its respective report, now I would like to know if it is possible to obtain the report of only one sequence in TestStand 2012?
(2,697 Views)
(2,665 Views)
Can you share your sequence please
(2,660 Views)
Okay, I told you that the sequence was generated using the ATMLToolkit 2012 tool.
(2,651 Views)
This topic may be related to this other forum
Best Regards.
Omar R.
Technical Support Manager
CLA | CTD
(2,644 Views)
