NI TestStand
Breakpoints do not work and icon is white TS2016f2 64-bit
Irrelevant how I got here but did delete MAX configuration about same time as problems began, but I have a white-outlined stop sign as the breakpoint icon and the breakpoints do not stop execution.
Have uninstalled TS and LabVIEW (both 2016, 64-bit) including drivers and reinstalled (a few tool-kits remained), TWICE and same problem remains.  Short of removing EVERY piece of NI SW (I know there is a command to do so, can't recall) I am out of answers.  Any takers?
Thanks, Dave
(2,751 Views)
Accepted by topic author PoolMaster
Are you breakpoint icon like that ?
If yes, that means that your breakpoint is disable. Go to the Debug, Breakpoints/Watches... menu and enable it
Regards
(2,719 Views)
