NI TestStand
Finish the test when a condition is not met in one of the sequences, using ATML Toolkit
Greetings ... I tell you that I am new to TestStand and I would like someone who has managed to generate sequences from the ATML Toolkit tool. A couple of days ago I have been doing a test system for electronic cards in TestStand 2012 and using the ATML Toolkit 2012. My question is how can I complete the whole test if one of the conditions is not met within a sequence, until now I have I tried to implement this process in the Test Description (XML) file in the TestGroups <Conditions> section but I did not achieve the result that I require. Someone who can help me with this doubt please, thanks in advance. I leave the file Test Description attached.
(2,258 Views)
To be more specific I would like tobe able to stop the test in its entirety if one of the steps of any of the 4 sequences has failed.
(2,228 Views)
