NI TestStand
TestStand 2017 Sequence Editor Missing from Windows 10 Start Menu
I installed TestStand 2017 on a Windows 10 machine. The installation was uneventful, except I cannot find an entry for the Sequence File Editor in the Start Menus. Searching shows Sequence Analyzer, Sequence File Converter, etc. I browsed to the National Instruments folder in the Start menu, but no entry for the sequence editor. In fact, all TestStand entries are in the top level 'National Instruments' folder, which makes for a very messy folder (see the screenshots below).
The Sequence Editor is installed and appears to work. I pinned it to the Task Bar once it was opened.
Is this me, or is there a problem that the installer team should be made aware of?
Screen shot showing the results of a search using 'testst'
TS Start Menu.png:
Screenshot of the National Instruments Start menu folder:
NI Start menu folder.NI Start menu folder.
David C
(2,605 Views)
Thanks for your observation. I will do further research on this and will contact R&D if this is a non expected behavior.
(2,571 Views)
