NI TestStand
Getting Context from .NET assembly
Hi all,
I have a .NET assembly called by TestStand, but I don't have the context.
Would it be possible to get the current contect through the windows thread ID corresponding to the TS thread ID ?
Thanks for your help
(1,080 Views)
I assume you are referring to SequenceContext. Do you control the source code?  And can you update to the function signature to add a parameter to pass a reference to the SequenceContext?
(1,029 Views)
Thanks for you response.
If I ask the question, it's because I can't pass sequence context by parameter.
I'm pretty sure that I can get sequence context from curretn windows thread.
But I don't see which API functions I have to use.
(980 Views)
Are you passing any NI TestStand objects?  And is your code built with TestStand API library?  If not, then even if you somehow got a reference to a NI Object in memory, I don't know how you would process the properties contained within it.
(970 Views)
My code is built with TS API.
When I need the sequence context, I have a reference to TS Engine object and I can get current windows thread though .net framework.
(953 Views)
