NI TestStand
Getting Value of variable when given name of variable
Hello all,
I have some fairly complex logic with ternary operators and I have ran into a snag.  I am using Step.TS.SData.ViCall.Parms.ArgVal to return the input values for my VIs.  However, when I use a variable as an input for my VI, Step.TS.SData.ViCall.Parms.ArgVal will return the variable's name.
An example would be:
Step.TS.SData.ViCall.Parms["RemoteIP"].ArgVal returns Locals.IP
Rather than
Step.TS.SData.ViCall.Parms["RemoteIP"].ArgVal Returns 192.168.0.1
Is there a way to return the value of a variable rather than its name, or evaluate its value given the name?
Brady James
(3,597 Views)
Accepted by topic author BradyJames
Hi James,
You should take a llok to the TS function 'Evaluate'.
You can easily use it within an expression to get the value contained in a variable only know by its name (as a string).
To find it, click on f(x) within an expression edit box and take a look to the 'Operatros/Functions' tab, section 'Functions', line Other.
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(3,587 Views)
Thank you very much! This worked great!
(3,559 Views)
