NI TestStand
Modyfing Teststand Operator Interface
Hi
I made the following small changes:
  • Automatic run of the Sequence.
  • No Login window.
But I can't get the Execution View to be updated
I don't know exactly why and I don't know exactly how to correct it.
Does anybody has any Idea?
These are the main changes I made:
Regards.
My Channel: https://www.youtube.com/@LV_Lab
(2,905 Views)
It worked fine for me when I hardcoded a path into the sequence file path (because I didn't know what your element functionality was doing).  The execution view updated correctly.
See attachment.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,887 Views)
Thank you for testing it.
I tried with the path directly connected but it doesn't work.
I tried both with a dummy sequence File that just calls another VI and with my actual Sequence File and it doesn't show anything.
Do you think it may have something to do with my Station Options configuration in Teststand?
(2,883 Views)
I found the problem.
This is embarrassing but the Enable Tracing in the Station Options was not set true.
Thanks again!
(Should I mark the solution as Solution? It was a really silly question)
(2,877 Views)
Glad it is working!
jigg
CTA, CLA
testeract.com
(2,871 Views)
