NI TestStand
Getting error 1035 using teststand deployment.
Whenever I do a Teststand deployment and I select to password protect my VI's, I get a very freindly and descriptive: Error 1035. I assume (because I am a LV user and have been trained to decode cryptic error messages) that this means that one of my VI's cannot be password protected. Any help is appreaciated.
Michael Aivaliotis
VI Shots LLC
Message 1 of 17
(5,710 Views)
I have more info:
Error 1035 occurred at Invoke Node in TestStand - Lock Heirarchy.vi->TestStand - Build VI Distribution 8 AX Wrapper.vi->TestStand - Build VI Distribution 8 AX Wrapper.vi.ProxyCaller
Possible reason(s):
LabVIEW:  Operation is invalid for this type of VI.
Method Name: Lock State:Set
So looking up this method help in LabVIEW indicates that the problem may be that the TestStand Deployment tool is trying to password protect type definitions which is not allowed.
Michael Aivaliotis
VI Shots LLC
Message 2 of 17
(5,690 Views)
I'm getting further along. I figured out that the problem is that there is a bug in your VI locking code. I figured this out because I removed strict typedefs from my project and it still didn't work. I then narrowed it down to other code types and concluded that the problem is Global VI's. Apparently you cannot password protect Globals. My project has one global VI. I removed it and it got further along in the build. This also indicates a bug in the LabVIEW documentation because it states you can lock globals, which is true, but you can't give them a password. So I'm getting further as I stated but now I'm getting error 1004 (LabVIEW:  The VI is not in memory.). I'm still investigating...
Michael Aivaliotis
VI Shots LLC
Message 3 of 17
(5,681 Views)
I think that the issue may be with using *.lvlib files? Basically I'm calling a VI from within a TS sequence that is located inside a LabVIEW *.lvlib file. Could this cause problems when building a deployment?
Michael Aivaliotis
VI Shots LLC
Message 4 of 17
(5,676 Views)
Michael
What versions of TestStand and LabVIEW that you are using?
Anand Jain
Message 5 of 17
(5,653 Views)
Using TS4.0.1 and LV8.5
Michael Aivaliotis
VI Shots LLC
Message 6 of 17
(5,652 Views)
Michael
Can you post a simple example which displays the above error(s).
Thank you
Anand Jain
Message 7 of 17
(5,650 Views)
I was able to reproduce this error 1004 in a dummy project. Find it attached. The 1035 error is easy to reproduce on your own by just including a globle VI in the build.
Michael Aivaliotis
VI Shots LLC
Message 8 of 17
(5,647 Views)
Hi Michael,
I have been able to reproduce the error on my end and I have something I would like you to try.  The proper way to deploy a Project Library (*.lvlib) from TestStand is to insert a Deploy Library step before you call the VI with the shared variables.  To get the Deploy Library step you right click in your sequence and go to Insert Step » LabVIEW Utility » Deploy Library.  Right click on this step and go to Configure Deploy Library...  Change the Library Path to the Project Library (*.lvlib) that contains your shared variables.  Set the Operation to Deploy.  When you are done calling the VIs, you need to Undeploy using the same step.  Set the Operation to Undeploy.
Also, make sure you add the .lvlib file to the workspace as well.  In the example you posted, when I completed these steps, I could build the deployment successfully.  I hope this helps!
Matt S
Message 9 of 17
(5,599 Views)
This is not working for me. I did everything you mentioned and now i'm getting:
Internal error code 1059
Also, I'm not sure why you mentioned shared variables. I'm not using shared variables.
Message Edited by Michael Aivaliotis on 03-06-2008 10:43 AM
Michael Aivaliotis
VI Shots LLC
Message 10 of 17
(5,590 Views)
