NI TestStand
Getting error 1035 using teststand deployment.
Michael,
I will need to do some more research why you are receiving that error.  In the meantime, could you try building my sequence and workspace to see how that works for you?  Thanks!
Matt S
Message 11 of 17
(1,837 Views)
Your file doesn't work. Remember, the issue is we want to password protect the VI's in the target. You have this feature off in your deployment file.
Michael Aivaliotis
VI Shots LLC
Message 12 of 17
(1,832 Views)
Michael,
I'm sorry for all of the confusion.  I have been working with our R&D department and have a solution for you.  Please contact National Instruments at your earliest convenience.  Thanks!
Matt S
Message 13 of 17
(1,807 Views)
I received the patch you sent me via my support ticket and it has solved both issues I had. I suggest you make this patch available to others via the support website as a support article or attach it to this thread. Thank you for fixing this.
Michael Aivaliotis
VI Shots LLC
Message 14 of 17
(1,777 Views)
We encounter from time this problem using TS3.5 & LV8.2.1 when we have Global variable VI.
Could you publish as soon as possible the patch? Or at least sent to us
Luigi Magni (System Engineer - CTA)
Message 15 of 17
(1,767 Views)
Hello Luigi,
If you think that this patch would be applicable for your situation please contact NI Support to request it and we will be more than happy to work with you to make sure we can resolve your issue as well.
John B.
Message 16 of 17
(1,728 Views)
Good news!
The patch mentioned in this thread is now available from our website as a patch for TestStand (versions 3.5 & 4.0.1f1).  You can find more information on this problem and the files here: KnowledgeBase 4JDB8NT3: TestStand Deployment Utility Generates Internal Error When Locking VIs in Pr...
John B.
Message 17 of 17
(1,703 Views)
