Getting the saved status of a Sequence file Loaded in TS
Hi All,
Please let me know if there is any Sequence or Sequence File property to programmatically find if the current sequence loaded in teststand is saved or not.
Thank You,
Sree Ranjani.
(2,528 Views)
Accepted by SreeRanjaniSG
Hi Sree,
You could check to see if the sequence file has been modified, using the following expression:
RunState.SequenceFile.AsPropertyObjectFile.IsModified
I hope this helps,
Charlie
Charlie Rodway | Principal Software Engineer | Certified TestStand Architect (CTA)
Computer Controlled Solutions Ltd | NI Silver Alliance Partner | GDevCon#1 Sponsor
(2,515 Views)
