NI TestStand
Help File in Common Sequence Call
I am using TestStand on a large project that has many test engineers involved. We have hundreds of common sequences that we have written to save time, and most require the passing of variables and types. We have separate .html help files for each sequence, but it is a waste of time to navigate to and download them. The ActiveX Specify Module box that is similar includes a link to help files. Does anybody know how I would be able to add this functionality to our common sequence calls? I appreciate your help. Bryan
(2,954 Views)
Hello Bryan,
I found a thread here that seems to deal with a similar issue. See if the suggestion in there works for you. Thanks!
Ebele O.
(2,935 Views)
