NI TestStand
Is there any differnce between the Numeric Limit Test source code from TestStand 3.0 to TestStand 3.1? How to get the source code for the Numric Limit Test for both the versions?
I need to know the differnece between the Numeric Limit Test between the TestStand version 3.0 to 3.1. If there is any differnec in the source code how to find it out? If somebody has the code can you share it?
Jeyan
(3,203 Views)
I don't believe there are any differences between the two versions. But you can check the source code for the Numeric Limit Test in TestStand\Components\NI\StepTypes\CommonSubsteps. But the main part of the step is the Code Module and this bit the users supplies this.
What has prompted this question?
Regards
Ray Farmer
Regards
Ray Farmer
(3,192 Views)
