Help needed dynamically writing to local variables
Hi folks
I am using a numeric limit test
The test is within a loop, and the current iteration is stored in a local variable
I am entering an expression in the Post-Expression field, and need to achieve the following:
If step fails, variable[iteration.local].local = Fail
So for example:
If step fails, variable1.local = Fail
This allows me to identify in which iteration the failure occurred, so I can record the result against the correct DUT in the batch that is looping.
Can someone tell me the required syntax to achieve the statement?
Thanks!
Message 1 of 8
(3,252 Views)
Accepted by Tom0000
Is this array variable a Boolean?  A String?  If a Boolean, then you could simply use Locals.Variable[Locals.x] = Step.Result.PassFail in the Post Expression. If a string, you could use Locals.Variable[Locals.x] = Step.Result.Status in the Post Expression.
Message 2 of 8
(3,218 Views)
Ah great, yes a boolean is fine thanks for the syntax I will try that!
Message 3 of 8
(3,191 Views)
Hi, the following didn't work:
I got the following:
Unknown variable or property name 'Locals.Variable'.[Error Code: -17306, Unknown variable or property name. ]
Basically it did not insert the number from the variable in the square brackets and match the aimed variable.
How can I get that number in there? I have a loop that runs 6 times, and need it's iteration on the end of that local variable name, in order to store the result for each DUT in it's own variable.
Thanks!
Message 4 of 8
(3,090 Views)
Assuming you just configured the Numeric Limit Test to Loop:
Locals.Variable[RunState.LoopIndex] = Step.Result.Status
Message 5 of 8
(3,081 Views)
Hi
The numeric limit test itself does not loop, but it sits in a much larger loop where each DUT runs all it's tests, then loops 6 times for 6 DUTs. So I just need the current DUT number on the end of the local variable, allowing me to store each DUT result in a unique variable.
Thanks!
Message 6 of 8
(3,072 Views)
That error points more to you didn't have that variable (Locals.Variable) declared or it is not defined as an array.
Message 7 of 8
(3,057 Views)
Great, thanks!
Message 8 of 8
(3,032 Views)
