NI TestStand
Help with select function
Well guys, I have a problem here and I didn't find any solutions
So maybe someone of you, can help me!
My problem is:
I have 2 numbers (100 and -200) and I have to plot the greater value.
The problem is for me the signal of -(minus) doesn't means nothing....
For the program I'm making, the -200 is greater than 100
So I tryed put bouth as absolute value, but when I have the "answer" only appears the "200"
and I need it appears -200
So I thought about something like that:
I use a select function and maybe do something like that:
So I have to make something at True or False value at S to make this work!
If true I receive 100, if is false I receive -200
Thanks!
(4,212 Views)
What does this have to do with TestStand?
Yes, the select function will work just fine. You would wire the result of your comparison to the absolute values.
(4,210 Views)
I dont know why is in this section. I posted it on LabVIEW part!
Well Dennis I make it like that:
But now I have a problem
I do the same calc for 3 differents variables like A, B, C
and after that I have to calc which value is the "greater"
But my problem is, If I have the values "-350 300 -400"
the greater will be "300" but for me the "minus" don't mean anything
so I need the greater value is "400"
For all positive values, its works fine!
I compare A and B, after that the greater is compared with C and have a result!
but When I have negative values and positive values... I got that problem...
and When I have only negative values I have a problem too.
"-300 -400 -500" for me the greater value have to be "-500" but labview shows "-300"
because -300 is greater than -500 in algebriac.
And If I use absolute values I will always have a positive value... but I need to know if the value is negative or positive
Anyone, can help me with that?
Message Edited by EduU on 10-29-2009 11:06 AM
(4,205 Views)
I don't understand your logic.
(4,190 Views)
