NI TestStand
teststand 3.0 operator interface sometimes just vanishes.
Hallo, we control a testsetup in a temperature chamber with teststand 3.0 (batch model). The testsequence runs about 14 hours. So the the operator starts the sequence in in the afternoon and gets the results next morning. Now it happens from time to time ( about once every two months) that the operator starts the sequence in the afternoon and the next morning the operator interface (standard labwindows CVI operator interface), which is the only application running on that Windoes XP computer, has just vanished. No error message, no crashlog, nothing. The only thing which exist, are the report files with zero bytes lenght. We've allrady added some logging code to our teststeps (written in Labwindows/CVI) and we know now that our last teststep does it measurement.
Any ideas what might cause this or how I can debug that ?
Are there logging options in teststand, which log the teststeps also in the model sequence to get an idea in which teststep the sequence fails ?
(3,290 Views)
If you use On-The-Fly reporting, you can capture every step in your sequence file as it executes. If you modify the process model to include results on any step, it will also be captured by the reporting.
Allen P.
NI
(3,274 Views)
I realize this issue was posted many years ago, but does anyone know what the solution was to this problem?
I am seeing the exact same issue.
(2,989 Views)
