NI TestStand
Hi Im trying to get the Station ID into a VI using property method using TS 3.1 and LV7.1
Hi Im trying to get the Station ID into a VI using property method , but I dont seem to be able to find a property path to it? Im using the sequence context control in the VI for other parameters, but I guess I need a different strategy for Station ID?.
Any suggestions!!
thanks dht
(3,558 Views)
You can use the same strategy to get the Station Id. Use this property path "RunState.Root.Locals.StationInfo.StationID"
A simple way to find property paths for the things you are looking is using a breakpoint in your sequence. When you are paused go to the Context tab in the execution window and browse through the properties. You can also use the Find option from the Edit menu to find property names or values.
Good Luck,
Marcela
(3,550 Views)
Thanks Marcela - It worked fine and some good tips.
thanks dht
(3,520 Views)
Yo, Architect Supreme,
It was so cold this AM, rock salt wasn't working!
Miss Pgh yet?
Ben
(3,487 Views)
