NI TestStand
Highlight steps which reference a particular variable
I am using TestStand 2014.
It would be nice if I could right click a variable in the variables pane and choose from the context menu "highlight steps which reference this variable" or words to that effect and then the background of each step which referenced that variable would alter.
It would be really nice if it happend just by hovering my mouse over a variable.
I know this can be done by using a search but it is rather clunky
(2,543 Views)
This is probably something you should propose via the TestStand Ideas Exchange. I've had a quick look and can't spot anything similar already on there. I think it could be nice to have.
(2,520 Views)
I did have a search through the ideas exchange for TestStand and couldn't see it, however, as a bit of a noob who is using an old version of TestStand, I thought it better to make sure it wasn't already implemented in a newer verion.
Have now posted the suggestion to the ideas exchange.
(2,507 Views)
