How Can i use 2 sequencess simultaneously ?
Hello ,
I have just recently installed TestStand 4.2.1 , I am trying to understand , can i use 2 sequencess simultaneously ?
Kobi .
Kobi Kalif
Software Engineer
(3,533 Views)
I'm also a beginner but maybe you should take a closer look at the 'Sequence Call' Step. There you can set options like execute 'in new Thread' or execute 'in new Process' for a sequence.
(3,529 Views)
Accepted by Kobi_K
Kobi,
what do you understand with "use sequences"?
If you are talking about "executing two sequences in parallel", then the answer is yes.
In order to understand parallelism in TestStand, i suggest you to learn more about:
- General TestStand knowledge
- Process models
hope this helps,
Norbert
PS: You should think about attending a TestStand course
Norbert
Expert: Geometry
(3,527 Views)
Thank you for the answers ,
I followed by the instructions in the User Manual it didnt worked at the first time i tryed , but now its working very good .
Kobi Kalif
Software Engineer
(3,523 Views)
