How I can log Sequence File version number to database?
As in the subject.
There is nothing like that under Logging object.
Message 1 of 9
(7,798 Views)
Do you need it in a separate field in the databse?
One option is to just add it as an additional result in a step in your sequence file.
RunState.SequenceFile.AsPropertyObjectFile.Version
Hope this helps,
jigg
CTA, CLA
testeract.com
Message 2 of 9
(7,751 Views)
Hi ~jiggawax~,
Yes, I knew that I can report it as additional result, but I was thinking that it should be a part of a logging schema, or I'm missing something.
I think I shall propose that the sequence file version number should be a part of Logging schema/container.
K.
Message 3 of 9
(7,736 Views)
The schema is something that you can easily change yourself. In my models, I used a highly modified UUT container but you don't have to go that extra step.
Message 4 of 9
(7,717 Views)
Hi Dennis,
Could you point me more explicitly to how to add something to the logging schema by modifying UUT container?
Message 5 of 9
(7,708 Views)
Message 6 of 9
(7,703 Views)
Accepted by MimiKLM
Here is how I did it:
Configure -> Results Processing -> Database Options -> Schemas tab
Copy + Paste Generic Record Set
Under the new schema open UUT_RESULT
Add a new column - varchar type
Set the value to Log as RunState.Caller.SequenceFile.Data.Version
Message 7 of 9
(6,415 Views)
I've accepted that as the solution. It is very good.
However, one small  bug.
There is no Data API method under SequenceFile context
I'm  usin g TS2014SP1 x64
Message 8 of 9
(6,403 Views)
I think it shows up only during runtime.
Message 9 of 9
(6,366 Views)
