How Teststand determines the final status of a sequence
Hello
In my application I created a custom limit test, the step.result can be either "passed", "failed" or "passed but ..." ( I mean that the data are inside the limits but to close of these limits)
Now I want that the final status execution of my sequence must be "passed but" if one of my custom step have this status.
I would like to know where teststand determines the final execution status, should i modify the process model to watch the result list and fix the status of my sequence at "passed but " if i see one ??? I s there another way
In relativ sophisticated test sequenceur the final status can be different than just "passed" or "failed"
(4,242 Views)
Your question is very interesting but why not using the ReportText to add extra information in the report (for the step or the sequence call)?
When you have edited your custom step, i assume you have used the container Step.Result.status to send the result of your step..
You can customize everything and create your own result list to have a step following the behavior your are expecting...
But i think that you have to programmaticaly  change the status of a sequence call depending on the result of the steps inside it.
Kamal
NIF
(4,215 Views)
Thanks for your answer
Actually my question was to determinate the final status which is written in the report. I create my own data test report , and the specific status is written in it, fot that non problem. My problem is to know how is determinate the final status of a sequence file, i managed to set the status of a sequence at "ok but" (if one of my step status is this one) , using caller.step.result ... but it is not possible for the main sequence....
i hope it is just for the moment !
(4,199 Views)
Hi
you should look at the following container:
"RunState.Caller.RunState.Sequence.Main["MainSequence Callback"].Result.Status"
kamal
(4,186 Views)
Hi
kamal
Hello Kamal
Under the "RunState.caller" I have found nothing.
Would you tell me which window I can see the "RunState.Caller.RunState.Sequence.Main["MainSequence Callback"].Result.Status"
Thank you.
(4,064 Views)
Hi
You have to check this property while tour callback is executed.
You can set a breakpoint after the mainsequence callback of your processmodel.
kamal
NIF
(4,042 Views)
Kamal,
I got, thank you.
(4,032 Views)
