I will try to answer your question. But why don't you do it manually using MAX ?
You can use the Ivi Configuration Server to do it (TestStand ActiveX adapter). But I didn't find any help file.
I found only a big documentation (the specifications) from the Ivi Foundation web site :
http://www.ivifoundation.org/Downloads/Architecture%20Specifications/IVI-3%205_V_1%205_Approved.pdf
So I developped a sample sequence for you :
The sequence finds the logical name defined in "Locals.NAME_TO_FIND" (DMM here).
If the name is found, I get the driver session and set the "Query Instrument Status" to False.
Regards
Bruno
Message Edité par bruno_p le
12-12-2007 02:46 PM
