NI TestStand
How can I control what is desplayed when seq run?
Can I control what is displayed on the screen when the sequence run?
I found out how to disable the tracing into setups and cleanups, but, how can I display only the top level steps?
Can I display top level and second level ?  etc...
Rafi
(3,181 Views)
Hey Rafi,
Are you talking about tracing into sub sequences?  You can turn those off in the actual sequence call step.  In the Run Options under properties there is a Sequence Call Trace Setting.  Set it to Disable Tracing in Sequence.
And make sure in Configure>>Station Options on the Execution tab that you have the Allow Tracing into Sequence Calls Marked with Tracing "Off" unchecked.
Hope this helps.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,140 Views)
Hi Rafi,
Checkout the Sequence Tracing section of the following link
http://zone.ni.com/devzone/cda/tut/p/id/7559
It may be of use.
Regards
Ray
Regards
Ray Farmer
(3,126 Views)
