NI TestStand
IF THEN Else in TestStand
Could anyone please provide me an example for IF THEN ELSE in TestStand? I have 3-4 steps (LabVIEW modules) in a sequence, which use VISA. Somehow the connection losses in between. If “connection lost” happened, I would like to clear the error and reopen the VISA and go back to the first step. I have a global variable which monitor the number of “connection lost”. If this exceeds a certain limit, I need to stop the execution.
Any simple example…?
Thanks in advance.
Sanad MM
(4,421 Views)
Hi Sanad,
We provide an example of some of our Flow Control Steps in the examples folder:  <TestStand Directory>\Examples\SequenceFlow.  The "UsingFlowControlSteps.seq" will be a good example to start with.  I hope it helps!
Matt S
(4,371 Views)
