NI TestStand
How can I determine if record results is checked
I need to be able to determine if the "Record Result" box has been checked from inside of the SequenceFilePostStep callback after each step has been run. Is there a boolean variable that stores this information. If not, is there any other way to find this out?
(3,424 Views)
Hi Steve,
The property is Step.TS.NoResult
So it 'd be something like RunState.Caller.Step.TS.NoResult
Ignacio
(3,423 Views)
The TS parameter under step does not appear to exist in the SequenceFilePostStep callback.
(3,418 Views)
Looks like it does exist. It just wasn't showing up under any of the variable windows.
(3,415 Views)
You probably do not have Hidden Properties visible (Configure » Station Options » Preferences).  You can access the step through the
Parameters.Step field.  In general, I wouldn't recommend counting on Hidden Properties for locating these variables- it is much safer in case we change implementation to use the API.  You can use the Parameters.Step object, and call the Step.RecordResult API method (in 4.0 through an expression, or in previous versions in an ActiveX step).
Allen P.
NI
(3,414 Views)
