NI TestStand
How do I close a generation session in C#
   Please see the code below, how do I close the generation session after I have completed the io operations?
static void Main(string[] args)
/* start of main */
string card_name = "PXI-6552";
bool id_query_status = false;
bool reset_instrument_status = false;
string output_channels = "0,1,2,3,10,11,12";
string input_channels = "13";
uint misc_counter=0;
uint write_data=0x00000000;
uint mask_value=0XFFFFFFFF;
niHSDIO sig_gen = niHSDIO.InitGenerationSession(card_name,id_query_status,reset_instrument_status,"");
/* create a generation session to the Digital IO card */
sig_gen.AssignStaticChannels(output_channels);
sig_gen.ConfigureDataVoltageLogicFamily(output_channels,InstrumentDriverInterop.Ivi.niHSDIOConstants._33vLogic);
misc_counter = 0;
while(misc_counter <= 10000)
sig_gen.WriteStaticU32(0x00000000,mask_value);
sig_gen.WriteStaticU32(0xFFFFFFFF,mask_value);
Console.Write(misc_counter+"\n");
misc_counter++;
} /* end of main */
How do I close the generation session?
Kaspar
Kaspar
(4,288 Views)
Hello Kaspar,
You should be able to close the session by calling sig_gen.Dispose() method to properly dispose of the object handle.  There is a helpful example you could reference here which runs a basic HSDIO acquisition session and demonstrates using this command.
John B.
(4,262 Views)
Kaspar,
I have some more information that might help explain how (and why) the Dispose() method works.  If you look at the definition of Dispose() you see that it calls a private method, Dispose(bool). This wrapper function contains a direct call to the Close() function imported from niHSDIO.dll.  Thus you are calling the Close() method that you are probably used to seeing in the C version it has just been updated to work in C#.  Hope this is helpful!
public void Dispose(){
  this.Dispose(true
  System.GC.SuppressFinalize(
this
private
void Dispose(bool disposing){
  if ((this._disposed == false
    PInvoke.close(
this
._handle);
    this
._handle = System.IntPtr.Zero;
  this._disposed = true
John B.
(4,239 Views)
