NI TestStand
How can I load Variables from a file ?
I'm searching means to load automatically FileGlobals variables used in all the sequences from my "Test sequence" :
Test sequence
   | -- Sequence 1
   | -- Sequence 2
   | -- Sequence N
in the aim to only have to change the .txt or .csv file (or .xls...).
Thank you.
(4,850 Views)
You can use Tools --> Import/Export properties tool.
If you want to do it dynamically use Property loader step type does that.
Refer property loader example ( In the example folder of TestStand).
(4,848 Views)
Thank you for your answer.
I did but, maybe I'm wrong, this tool loads only properties of variable, not the variables. I would like to create these variables dynamically when I load the subsequence...
I look one more time the example ... 😉
(4,845 Views)
Accepted by TestStander
If you are asking to create variables dynamically you can refer this link :
http://forums.ni.com/t5/NI-TestStand/Is-there-a-way-to-generate-variables-while-in-the-sequence/m-p/...
(4,840 Views)
Thank you.
I'll do with these commands.
(4,832 Views)
