NI TestStand
How can I programmatically list step names inside the sequence file
I need to list all the steps inside the TS sequence file. E.g. sequence.seq file cointains main-sequence and it contains following steps:
step1
step2
step3
step100
I can easily select all these steps and then copy-paste them into the excel sheet. However, I would like to do this programmatically because I have many .seq file containing many steps.
Can you help?
(4,852 Views)
Accepted by esanum
Hi esanum,
Have you seen this?
Eirikur Runarsson
(4,831 Views)
That is exactly what I need. Thanks a lot for the tip Eirikur!
(4,751 Views)
