NI TestStand
How can I programmatically list step names inside the sequence file
I need to list all the steps inside the TS sequence file. E.g. sequence.seq file cointains main-sequence and it contains following steps:
step1
step2
step3
step100
I can easily select all these steps and then copy-paste them into the excel sheet. However, I would like to do this programmatically because I have many .seq file containing many steps.
Can you help?
(4,846 Views)
Accepted by topic author esanum
Hi esanum,
Have you seen this?
Eirikur Runarsson
(4,825 Views)
That is exactly what I need. Thanks a lot for the tip Eirikur!
(4,745 Views)
