How can I read information that appears in the report, within a sequence?
Hi
I would like to be able to access the UUT serial number, start time and test result, once the main sequence has finished, within Cleanup - is there a way of doing this? I'm using TestStand 3.1 and Labview 7.1.
(3,279 Views)
You could do this by including The ProcessCleanup sequence callback in you Sequence File.
Within this sequence you can access
RunState.Caller.Locals.UUT.SerialNumber for the serial number
RunState.Caller.Locals.Report for the whole report
RunState.Caller.StartTime.Text for the start time
Regards
Ray Farmer
Regards
Ray Farmer
(3,274 Views)
Hi knigth2
just visit this page Colelcting step results data from process model?
http://forums.ni.com/ni/board/message?board.id=330&thread.id=17440
greetings
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,258 Views)
While you certaintly could use the method described in that post (navigating through the ResultList array), I think the alternate method (using a callback) is much simpler and easier.
Probably the PostUUT callback would be easiest, since it has a parameter directly for sequence result.  If you use the post UUT callback, you could use the following:
Parameters.UUT.SerialNumber     for the serial number
Parameters.Result.Status     for the status string
RunState.Root.Locals.StartTime.Text     for the start time
Message Edited by Josh W. on 12-13-2007 04:51 PM
Josh W.
Certified TestStand Architect
Formerly blue
(3,243 Views)
Thanks to all
that's a great help
Bruce
(3,210 Views)
