My system has some instruments such as DC supply, AC supply, what are not NI's, I would like to run them in TestStand with IVI steps. How can I use them, what kind of driver to use.
I installed 34970 IVI-COM driver from Agilent, but there is no related item found in MAX.
******************************** *The best Chinese farmer* ********************************
MAX and the built-in TestStand IVI steps are for IVI-C drivers. You can use the ActiveX adapter to call functions to call IVI-COM drivers. Do a search of the TestStand board for IVI-COM for more info.
