NI TestStand
How can I use Agilent 34970 and other instruments in TestStand with IVI drivers?
Hi
My system has some instruments such as DC supply, AC supply,  what are not NI's, I would like to run them in TestStand with IVI steps. How can I use them, what kind of driver to use.
I installed 34970 IVI-COM driver from Agilent, but there is no related item found in MAX.
*The best Chinese farmer*
(4,368 Views)
MAX and the built-in TestStand IVI steps are for IVI-C drivers. You can use the ActiveX adapter to call functions to call IVI-COM drivers. Do a search of the TestStand board for IVI-COM for more info.
(4,364 Views)
If you have installed IVI driver,you can find it in IVI Drivers in MAX.
for more info about IVI,you can go to http://www.ni.com/ivi/
(4,329 Views)
Check out this link:
http://digital.ni.com/public.nsf/allkb/5499F9DBD07522F686256F260066BA86
(4,285 Views)
