How can take a Custom Data Type in TestStand and create a LabVIEW DataType?
I am using LV 8.2 and TS 3.5.
I have an existing Custom Data Type in TestStand and I want to make a LabView Type Def.  The TS DataType contains 11 elements: a Visa Resource Container of 2 elements (String, DeviceName and Number, Session), 9 Numerics and 1 String Array.  For Backwards compatability, I cannot modify the TestStand DataType.
Jean
(3,632 Views)
Hi Goldee,
You should be able to do that. It's a two step procedure.
1) Creates in LV a custom datatype that maps 1:1 yours TS datatype.
2) Go in the TypePalette in the properties of yours TS Datatype and check into LV Cluster Passing Menu'. Here you can Connect a specific Field of the TS datatype to a Specific Label of the corresponding LV datatype. Once you've done it the TS datatype will result modified, I mean "starred" but the change you applied should not impact the datatype structure itself only the way you pass it to LV.
Have a good day
FiloP
It doesn't matter how beautiful your theory is, it doesn't matter how smart you are. If it doesn't agree with experiment, it's wrong.
Richard P. Feynman
(3,593 Views)
