10-02-2008 05:24 AM
I am using LV 8.2 and TS 3.5.
I have an existing Custom Data Type in TestStand and I want to make a LabView Type Def. The TS DataType contains 11 elements: a Visa Resource Container of 2 elements (String, DeviceName and Number, Session), 9 Numerics and 1 String Array. For Backwards compatability, I cannot modify the TestStand DataType.
Jean
10-07-2008 04:40 AM
Hi Goldee,
You should be able to do that. It's a two step procedure.
1) Creates in LV a custom datatype that maps 1:1 yours TS datatype.
2) Go in the TypePalette in the properties of yours TS Datatype and check into LV Cluster Passing Menu'. Here you can Connect a specific Field of the TS datatype to a Specific Label of the corresponding LV datatype. Once you've done it the TS datatype will result modified, I mean "starred" but the change you applied should not impact the datatype structure itself only the way you pass it to LV.
Have a good day
