NI TestStand
How do I Insert a Fileglobals Variable into a Step Name
Greetings Everyone,
     I'm curious, whether or not it's possible to insert a FileGlobals variable into a Step Name, whether it be an Action, Pass/Fail, Numeric Limit Test, or what have you.  An example would be "Paragraph 1.0 execution # {variable} running" were variable would be an incremental count, whether it be a for loop or any other type of senario.  Thank you in advance for any information that you may offer.
Scott
(4,192 Views)
You can do this dynamically in the Pre-Expression of the Step by using the TestStand API.
Step.Name = "Paragraph 1.0 Execution #" + FileGlobals.VariableName + " Running"
Something like that.  During run time your step name will change to that.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,186 Views)
Accepted by Scott754
Hi jigg,
     Thank for the reply.
     I tried it and Thank you.  It does exactly what I was hoping to do.  Many thanks.
Scott
(4,158 Views)
